Go Back   Rolex Forums - Rolex Watch Forum > Other (non-Rolex) Watch Topics > Patek Philippe Discussion Forum
Old 11 June 2019, 04:55 PM   #61
tom2517
tom2517's Avatar
Well that's a terrible looking bracelet conditions wise for a SS.
Assuming it's real and assuming it hasn't exposed to any harmful substances, it's probably a bad batch of steel.
tom2517 is offline   Reply With Quote
Old 11 June 2019, 10:22 PM   #62
enjoythemusic
enjoythemusic's Avatar
Real Name: Steven
Patek Philippe 1579 chronograph circa 1954
Sooo miss the days of Patek true quality.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming 'Wow! What a Ride!'” -- Hunter S. Thompson
Sent from my Etch A Sketch using String Theory.
enjoythemusic is offline   Reply With Quote
Old 11 June 2019, 11:00 PM   #63
dannyp
Originally Posted by S`` View Post
Exactly, they had it in screws before, then took it out of the design....
And people actually believed because it's due to the thickness of the bracelet?
Laughable
Sent from my VTR-L29 using Tapatalk
Admittedly, I cannot tell from the pics I see online whether there seems to be any substantive redesign of the bracelet that would precipitate the change. The one ting I do notice is this:
On the older version, the screw holes appear to go almost to the edge of each link. Is it possible that it was proving difficult to construct with such tight margins, or there was concern that wear over time would potentially damage the links, given how thin the area around the tube was?
Or perhaps I'm just looking for a justification that my speculation about bracelet thickness was the reason since I suggested that prior to knowing it previously had screws .
Originally Posted by Russell996 View Post
Presumably as a used piece after being reconditioned? PP aren’t going to scrap a watch for a simple service issue and they will need the papers to sell it on.
I have no idea, to be honest, whether it was being sold as used or new. I would hope preowned, but I hadn't ever seen any preowned pieces in the dealer's case. Perhaps at one of its other locations, though.
I certainly wouldn't expect PP to scrap such a piece either, and always wondered how such things were handled.
dannyp is offline   Reply With Quote
Old 11 June 2019, 11:25 PM   #64
Mbbgysam
Originally Posted by PJ S View Post
FFwd to 2:25
Thanks for sharing!
Mbbgysam is offline   Reply With Quote
Old 11 June 2019, 11:28 PM   #65
bonsai-man
Originally Posted by ts3 View Post
I'd prefer the 330 all day and twice on Sunday but I believe to remember the OP wrote elsewhere on TRF that he prefers the new dial + old movement version for its rarity. OP pl correct if I am wrong...
The difference in color / shine is not necessarily related to how old the watch is. The exact color / shine of stainless steel depends on the polishing - in this case on how worn the polishing materials / abrasive were when the new bracelet was made compared to the existing case. If you get a new watch the case and bracelet have been polished "together" so to speak. But w the new bracelet the wear status of the polishing materials will naturally have been different. Often you will see this as a Patek Service Center rep explained to me...
You are indeed correct, I saw a few incomings with the new 330 in April but was delighted to get my allocation towards the end of April with the old 324. A friend of mine got the same at the beginning of April (different AD). I did consider myself lucky to miss the price rise, now I am not so sure.
I just checked the watch again and since I cleaned it the rust has not come back yet, but it’s only been a few days. I can confirm the marks are not food, drink or from storage. I am still self-conscious wearing the watch and when I’m not it’s in the case.
I do not want the watch replaced or the bracelet re-polished/finished so soon after getting it. I may consider a replacement bracelet (if offered) provided it doesn’t show as someone on here pointed out. The main worry is should a new 5711 start rusting so soon, and will it come back in the future. The AD has asked to see the watch but there is nothing to see now, so not sure what they can do.
bonsai-man is offline   Reply With Quote
Old 11 June 2019, 11:47 PM   #66
dannyp
Did you see the post about how the bracelets are constructed? That was pretty informative in terms of possible explanations. It doesn't seem to be the bracelet itself that is rusting, rather perhaps the pin inside of it. Maybe it wasn't welded shut properly? Or there was moisture in the tube at the time? Or something else is leaking out? But if you take a look at the pics you posted in the OP the stain (whether rust or otherwise) appears to form a ring around where the tube was welded shut. If you look at the "healthy" link next to it, you can also see the vague outline of the welding.
Old 11 June 2019, 11:48 PM   #67
s.m.b.
s.m.b.'s Avatar
No, your new watch should not have rusted so soon... Once the rust reappears, ask for a replacement.
Rolex & Patek Philippe
s.m.b. is offline   Reply With Quote
Old 12 June 2019, 12:04 AM   #68
Murcielagoboy2
I'm at a loss to understand threads like these... "please help me etc"
Jeez - you've bought a new PP from an AD right? Take it back to them and get the part/watch repaired/replaced. Easy.
More generally, I'm fascinated by how precious people are about their 5711s. This isn't a dress watch - it's meant to be a daily beater. Mine is scuffed, scratched and worn in the pool, the sea, wherever. That's the point....
Murcielagoboy2 is offline   Reply With Quote
Old 12 June 2019, 12:14 AM   #69
dannyp
On the first point, agree entirely.
On the second, remember: For some veteran PP collectors, a 5711 is the most rugged, least expensive, watch in the rotation, while for others, newer to the brand, it's the absolute nicest watch they'll ever own.
Old 12 June 2019, 01:01 AM   #70
tom2517
tom2517's Avatar
Why cleaning it? I have to agree with Russell here and would just take it back to AD and at least demand a bracelet replacement, this is clearly not normal.
Don't think anyone should be needing to wipe 5711 with WD40 to prevent it from rusting.
Old 12 June 2019, 01:26 AM   #71
SearChart
TechXpert
SearChart's Avatar
Funny, they essentially downgraded the bracelet... But upgraded the price
Old 12 June 2019, 01:38 AM   #72
Rwatcher
Rwatcher's Avatar
Facts,
Mine has even braved the jacuzzi after plenty of drink
Nice dint on the bezel to remind me of that fun.
Rwatcher is offline   Reply With Quote
Old 12 June 2019, 02:48 AM   #73
beshannon
beshannon's Avatar
Real Name: Brian
Watch: One of Not Many
Really would like to hear what the selling dealer has to say
Vacheron Constantin Traditionnelle Complete Calendar, Glashutte PanoInverse, Glashutte SeaQ Panorama Date, Omega Aqua Terra 150, Omega CK 859, Omega Speedmaster 3861 Moonwatch, Glashutte Senator Exellence, Rolex 116710 GMT Master II BLNR, Breitling Superocean Steelfish, JLC Atmos Transparent
beshannon is offline   Reply With Quote
Old 12 June 2019, 03:48 AM   #74
brmeyers
brmeyers's Avatar
Real Name: Bryant
Watch: ...Your Thoughts
Wow, that is the first time I have heard that happening.
I had both a blue and white 5711. The white I kept the longest
and never even had the "thought" this could be an issue.
I am also very interested in what the dealer has to say about this.
brmeyers is offline   Reply With Quote
Old 13 June 2019, 12:28 AM   #75
bonsai-man
I’m at a total loss why member’s like this reply to threads they don’t understand or wish to contribute to. Why don’t they sigh and move on to the next incoming thread?
I don’t recall asking the forum if I should return the watch or ask for a refund. As for precious, I’m surprised you never used the same old “it’s just a watch” line from the Rolex forum. To be clear I wear all my watches including my dress watches and they all will be just as scratched as yours eventually, I just don’t go out of my way to scuff and beat them up unnecessarily, especially when new.
This is not a “please help me etc” thread. I started the thread as I thought other members would genuinely be interested to see and discuss the current build quality of modern steel PP, and to exchange thoughts on rust prevention on steel watches in general.This forum used to be a place where members shared experiences, idea’s and had discussions. Oh, I miss the pre-2017 days before the SS shortage.
I would have liked to provide an update to the forum once I had a reply from Patek Philippe and the AD, but as other members feel the same it would be best if the mods close this thread instead.
Old 13 June 2019, 12:42 AM   #76
Tha Baron
Tha Baron's Avatar
Corporations do corporate things I guess...
Tha Baron is offline   Reply With Quote
Old 13 June 2019, 01:25 AM   #77
Commonproject
looks like you've been eating too much spaghettios while wearing the watch
Commonproject is offline   Reply With Quote
Old 13 June 2019, 02:13 AM   #78
Passionata
Passionata's Avatar
Watch: the girls
I think it d be a shame to close it before we hear the suggested resolution from PP,
I m very much interested personally and technically.
TY
Best
George
"Also remember that feet don't get fat and a watch will always speak volumes." Robert Johnston
*new*https://youtu.be/EljAF-uddhE *new *
http://youtu.be/ZmpLoO1Q8eQ
IG @passionata1
Passionata is offline   Reply With Quote
Old 13 June 2019, 02:37 AM   #79
enjoythemusic
Real Name: Steven
Why close this thread? It would be appropriate that you started with a problem and in the name of fair / balanced reporting we read about Patek's solution.
As for using pins versus proper screws, that's soooo un-Patek-like and proves it's time to go F.P Journe, ALS, etc guys.
Old 13 June 2019, 02:41 AM   #80
subtona
subtona's Avatar
Real Name: gus
Watch: APK & sometimes Y
What was it resting on or in while it was off your wrist? This doesn’t just happen.
Old 13 June 2019, 02:49 AM   #81
V25V
V25V's Avatar
Agreed. I think just about everyone on here would like to see how Patek handles this. That just should not be happening to your watch.
V25V is offline   Reply With Quote
Old 13 June 2019, 03:07 AM   #82
masterserg
masterserg's Avatar
Real Name: Serg
Watch: AP
I don't think is a representation of Patek's quality. It can happen ... I had rust on a stainless steel AP 44 ROO lug (or whatever the small pieces that connect case with strap are called). I sent it to clearwater and they said the part in question probably came from an out of spec batch of steel. Thankfully it wasn't the watch case itself.
I suppose in this case PP should replace the bracelet and the OP (and PP) should have documentation of the issue in case it comes back later on, especially on the watch head.
How can you have any pudding if you don't eat yer meat????
masterserg is offline   Reply With Quote
Old 13 June 2019, 06:24 AM   #83
bruinmd
Real Name: Sal
Watch: Patek/Rolex/GS
If this is legit rust, this is absolutely insane. I would be taking this back to my AD ASAP and would be pissed.
bruinmd is offline   Reply With Quote
Old 13 June 2019, 07:21 AM   #84
bonsai-man
OK as I have contacted Patek directly its fair they have a chance to reply, also for balanced reporting on the forum lets keep this thread open for now.
I can also see some have an interest in the outcome, I don't epect a reply though after all my £23,000 purchase is probably not important to them. I will update the thread good or bad if or when I hear from them.
I also mentioned my 5167A which broke the wrong side of the 2 year warranty period, hopefully that may help to get the rust looked at. I'm reluctant to get it fixed as I read they just strip it down, clean it and put it back together so it will probably just stop winding again.
Sometime's I wish I just stuck with Rolex and Omega they have always been no trouble.
Old 13 June 2019, 07:49 AM   #85
Russell996
Russell996's Avatar
Have gone via your AD? If so, why do you not expect a reply? Of course they will reply and by return.
When you say you don’t want to get a 5167A repaired, can you explain as I don’t understand.
Update:
I see you posted back in August, piece was 4 years old not 2 years. Why did you not get it fixed last year?
https://www.rolexforums.com/showthread.php?t=621556
Russell996 is offline   Reply With Quote
Old 13 June 2019, 08:01 AM   #86
subtona
subtona's Avatar
Real Name: gus
Not sure how you come to your conclusions.
In my experience,
Patek has resolved several issues I have brought to them better than expected.
I would give them the time they need to review (things can move slowly with Patek.)
Rolex on the other hand could not have a worse track record if they tried, RSC has fixed one issue and created another ireperable problem; has charged me for a repair they did NOT complete; has not stood by their product and for the most part has been careless and carefree.
Old 13 June 2019, 08:37 AM   #87
bonsai-man
Update:
I see for the wrong side of 2 years we should read 4 years.
Correctiion to Update:
Yes the warranty was for 2-years, it had very very light use for less than 3 years, then it was cafefully stored undisturbedand and broke soon after I started wearing it in around year 4. So it broke itself somtime between 3 and 4ish years in storage
Strange thing is I looked at it again on Saturday wound it and it seems to be running fine now. Before it would stop after about 10 mins with 40+ turns of the crown. its been running fine for 4 days and keeping good time on anf off the wrist, very strange and unexplained.
Old 13 June 2019, 08:40 AM   #88
Russell996
Russell996's Avatar
Sounds like it needs a service.
Old 13 June 2019, 08:45 AM   #89
bonsai-man
In my experience,
My experience is different, I have never had a reply from Patek regarding several questions posed. My AD still has not sent my Omega warranty card even after 2 years of asking. When I looked for a new AD my current one somehow found out and threatened to stop my orders and remove me from ALL lists. No my experience has not been as good as yours, maybe I never spent enogh $.
Old 13 June 2019, 10:37 AM   #90
subtona
subtona's Avatar
Real Name: gus
Are you dealing with a Patek service center or an AD?
Perhaps it is a location variance.
In nyc the Patek service center consistently does the right thing.
Rolex consistently has failed.
Asset Appeal
Coronet
Bobs Watches
Copyright ©2004-2024, The Rolex Forums. All Rights Reserved.
