11 May 2011, 03:29 AM | #31 |
11 May 2011, 03:35 AM | #32 |
2024 ROLEX DATEJUST41 Pledge Member
Real Name: Jocke
Watch: A dozen of Rolex's
This message is written in perfect swenglish. What is best a custom Rolex or a Rolex that is stuck in custom? Buy a professional camera and you´re a professional photographer, buy a flute and you own a flute. |
11 May 2011, 03:36 AM | #33 |
Real Name: Jocke
I don't know anyone at the moment.
11 May 2011, 03:39 AM | #34 |
11 May 2011, 04:11 AM | #35 |
Real Name: Jocke
11 May 2011, 04:21 AM | #36 |
Real Name: Chris
Watch: 16610lv
The garage was open :) However the running an hour thing and closing the hood to let it dry didn't work (as the first responder said it wouldn't). When I get home tonight I'll try to take the covers off and see what's up and either use the air at the gas station or the hair dryer/fan.
Note to others... never drench your engine... yeah... you probably already knew that. |
11 May 2011, 04:42 AM | #37 |
Watch: IIc,1680 Red,16660
Actually, a bit of Googling netted this info...
The engine in your car is likely the M30B30. It was an older engine that went out of service after 1994. I -believe- if I'm reading accurate information that this engine had a distributor cap. This could also easily be the source of the problems. |
11 May 2011, 11:13 AM | #38 |
Real Name: Chris
Watch: 16610lv
Am I removing the wrong part?
11 May 2011, 11:22 AM | #39 |
Real Name: Chris
Watch: 16610lv
Just pop these off and blowdry?
11 May 2011, 11:23 AM | #40 |
Real Name: Jocke
Yes that is the connection to the fuel injectors. Ths plugs are below the black cover at the bottom in your pic.
Just pull off the middle part at the black cover and you found the plugs.
11 May 2011, 11:24 AM | #41 |
Real Name: Jocke
11 May 2011, 11:37 AM | #42 |
Real Name: Chris
Watch: 16610lv
Root of all evil...I hope
11 May 2011, 11:40 AM | #43 |
Watch: 16600,16570,6098
You may have to break out your sockets and take off the bolts holding the coilpack in, remove the coilpack and plug boot and blow all the water out.
I doubt its the coilpack connectors causing the prob. |
11 May 2011, 11:58 AM | #44 |
Real Name: Chris
Watch: 16610lv
This
11 May 2011, 01:05 PM | #45 |
Real Name: Chris
Watch: 16610lv
Thanks guys, I pulled the coils and there was plenty of water on both sides. I blew it out and towel dried it, and I have 2 fans on it this evening. I'll turn them on again in the morning to make sure I've got everything.
Thanks a million for the help!!! I'm sure it would have been an expensive trip to the mechanic. BTW, for anyone who is interested/following, I was using tapatalk to upload the pics and post while I was reading the recommendations, great technology. |
11 May 2011, 01:40 PM | #46 |
Nice one man!!! Feels good fixing your own stuff don't it !
Now you know you can swap your own plugs no problem :) Oh and for the record I nailed it first reply If it tripped the engine light you can reset most OBD1 systems but unhooking the battery for a few mins, if not do a search online on resetting the engine light for your model. You can probably reset the light by jumping a certain two connectors with a paperclip. |
11 May 2011, 02:09 PM | #47 |
Keep us apprised
11 May 2011, 02:32 PM | #48 |
Real Name: Tweek
Watch: out
Service note; BMW engines don't like water!
11 May 2011, 07:22 PM | #49 |
Real Name: Peter
Watch: The Game
You really drowned that engine, good job to fix the problem
5513, 7928, 1601(gifted to my daughter), 16610LV, 14060, 16610(Random serial),116610, ,79280P, 70330, 25600TB, 792500BM, M56000, 79030B, 25707B/21 (won this special watch), |
12 May 2011, 05:13 AM | #50 |
Real Name: Chris
Watch: 16610lv
Thanks again guys, put it all together this morning and it's running great. I'll never do that again (douse the engine). The great thing is that changing the plugs doesn't seem like such a leap now :)
12 May 2011, 07:38 AM | #51 | |
Real Name: Art
Watch: Sundial
If you decide to change the plugs, be careful when you remove the old plugs. Do not use excessive force to remove them. If you encounter resistance as you are proceeding, tighten them a bit and then try again, maybe letting them soak in a bit of penetrating oil. Use anti-seize lubricant on the new plugs. We don't want you back here asking for advice about stripped threads in the cylinder.
Rolex SS Oyster Perpetual no date, TT Datejust Member #13992 HM Power to the Superlative Panda, officially certified! HMPanda eats, shoots and leaves. Rolexers do it with perpetual movements. |
12 May 2011, 08:02 AM | #52 |
Now that you're an experienced techician it's time for you to open your watch and see what it looks like inside.
